98 mazda b3000
EMILYDONNA
my 98 mazda b3000 w/ 18x,xxxmiles, stick shift, 2wd, had the speedometer stop working. i changed the rear end from a factory rear to an open rear w/ 411's six months ago. recently the clutch started going bad. the speedometer failed before any issues w/ the trans, and after the rear end replacement. i've been told there is a vehicle speed sensor in the rear, but no parts store recognizes it in their system. my tach still works, and my abs light is on. why dont i have a speedometer??
Sep 23, 2007 at 9:38 AM
  • 75,988 POSTS
[quote:f9cefa7e83="emilydonna"]my 98 mazda b3000 w/ 18x,xxxmiles, stick shift, 2wd, had the speedometer stop working. i changed the rear end from a factory rear to an open rear w/ 411's six months ago. recently the clutch started going bad. the speedometer failed before any issues w/ the trans, and after the rear end replacement. i've been told there is a vehicle speed sensor in the rear, but no parts store recognizes it in their system. my tach still works, and my abs light is on. why dont i have a speedometer??[/quote:f9cefa7e83]
Its called the output shaft speed sensor located near the digital transmission range sensor at the transmission.
Sep 23, 2007 at 10:00 AM
