B3000 Truck idles rough at cold start-up.
HURONNIE
Hi, my truck a 1994 Mazda B3000 3.0 ltr. F.I. V6,170,000 miles, idles rough for the first minute or so at a cold start-up. After it senses that it's starting to warm-up the fast idle drops quickly and tries to die on me.
It just started to do it one morning when I was getting ready to go to work.
Normally when I first start my truck it goes to a fast idle at about 2000 rpm's and slowly drops to about a 1000 rpm's as it warms-up. This usually happens with in the first two minutes of start-up. But now when I start it up, it goes to it's normal fast Idle but then quickly drops and tries to die on me, so I keep tapping the gas pedal to keep the rpm's up until it senses the engine starting to warm.
I can see several sensors from the air intake to the carburetor but I'm not sure which one or ones would be the culprit.
I did attach a photo to show the engine and the one sensor by the top of the engine, above the water pump thinking it's that one cause it connects to the throttle in some manner.
I also took off the black shield that was covering that sensor because it was hidden from view.
I stopped by a car repair shop and they told me it would cost a $120 dollars just to hook it up to a computer to tell them anything.....which I expected, but was hoping there was some way for me to troubleshoot it by some process of elimination.
So is this some kind of water heater sensor issue or idle sensor?
Any help would be dearly appreciated, Thanks!
[img:5235581c50]http://www.2carpros.com/forum/automotive_pictures/106767_IMG_6915_1.jpg[/img:5235581c50] 8)
Oct 11, 2007 at 9:44 AM
  • 75,988 POSTS
Check the coolant temperature sensor and idle speed control motor stepper/IACV-take it out and clean it. also the throttle plate.
Oct 11, 2007 at 10:40 AM
SHOGUNNIX
Ever find out the answer to this? I have the same issue.
Sep 2, 2009 at 7:29 PM
FRNC11
If I am not mistaken, this is the same engine that Ford uses in the Ranger. If this is the case try changing the idle plunger and springs. After about 10 years the spring that adjusts the plunger snaps and the plunger sticks, causing the car to idle roughly and then die unless the engine is revved.
Dec 6, 2010 at 8:58 PM
