1995 Mazda B3000 Overheats and Smokes
What size motor?
Is the cooling fan coming on?
Are you having to add coolant?
The smoking thing is an issue and I'm pretty sure if the intake were leaking you would of found coolant in the oil by now. Chance are you have run 'hot' to many times and may have done some head gasket damage. I would have your system checked both hot and cold by a trained technician.
Cosmo...Mazda Tech
Jerry
Suggested Repair
Have a technician check the cooling system both hot and cold for head gasket damage after repeated overheating. An intake-manifold coolant leak is less likely if the oil stays clean. The water pump and thermostat were already replaced and the fan clutch was reported fine.
Conversation Summary
The owner of a 1995 Mazda B3000 3.0L reports weak cabin heat, a cool temperature gauge at speed, overheating in traffic that drops when the engine is revved, and heavy moist exhaust smoke after a short stop. Oil looks normal, the system has been bled, and plugs did not show a wet cylinder. The owner suspects an intake leak. The expert says an intake leak would likely show coolant in the oil, links the overheating to fan clutch, radiator, or thermostat issues, and warns that repeated overheating may have damaged a head gasket. A hot-and-cold cooling-system check by a trained technician is recommended.
