Clutch Pedal
1986 MAZDA TRUCK
190,000 MILES • 4 CYL • 2WD • MANUAL
LDKOGER
My mechanical knowledge is limited. The clutch pedal goes all the way to the floor when depressed and does not return to the starting position. You can pull it back by hand and it will stay there until you press it again. There's very little resistance when pressed. The fluid level in the master cylinder decreases but I can't see a leak anywhere. I keep adding fluid to the cylinder but it keeps leaking out. What could be causing the pedal to stay on the floor?
Sep 9, 2010 at 4:15 AM
Where is it leaking at, is it at the clutch master cylinder? If its leaking you gonna be losing the hydraulic pressure that will cause it to go to the floor-
Sep 10, 2010 at 2:44 AM
LDKOGER
Thanks for your help! I found the leak (and replaced the master cylinder) and it seems to be working okay now.
Nov 8, 2010 at 10:53 AM
WILLYJHOPUKY
  • 9 POSTS
how much did it cost to replace my 1986 mazda b2000 is doing same thing. thank you
Apr 26, 2019 at 2:05 AM
WILLYJHOPUKY
  • 9 POSTS
my fluid is staying full and the clutch is back up and can shift it. is it ok?
Apr 26, 2019 at 3:15 AM
  • 55,433 POSTS
Can you please shoot a quick video with your phone so we can see what's going on, that would be great. You can upload it here with your response.
Apr 29, 2019 at 5:13 AM
