1993 Mazda B2200 Clutch Slipping
RAFUSE
I am 17 and just bought my first vechicle and it is a 93 Mazda B2200 truck. It is 4 cy, 5 speed and my clutch is slipping or at lest thats what I think and my father thinks but I am wondering if there is anyway to adjust the clutch. It has a hydrolic clutch and I know nothing about it except where to check the fluid. If you could tell me if there is anyway in adjusting the clucth or how long it should take me and my father (who are wana-be back yard mechanics) to change the clucth entirely. Thanks
Jan 30, 2006 at 12:03 PM
DAEMON240SX
  • 17 POSTS
only way i know of to adjust the clutch is to just make sure the clutch pedal is at the right height in the cab. Changing a clutch isnt too hard a job and would probably solve the slipping issues. Go grab yourself a haynes or chilton manual for you car for $15 bucks and a new clutch kit (might grab the slave cylinder while your at it) and the manual should walk ya right through it.
Jan 30, 2006 at 1:57 PM
COSMO
  • 347 POSTS
Well if its slipping there is no hope for it, the tranny's got to come out. The clutches are NOT adjustable...don't try to adjust the pedal, there is none.
The tranny is pretty easy to get out fothe b2200.
Cosmo...Mazda Tech
Jan 30, 2006 at 2:00 PM
Suggested Repair
The hydraulic clutch is not adjustable, and the pedal should not be adjusted. If the clutch is slipping, the transmission must be removed and the clutch replaced; on the B2200 this is a relatively straightforward job.
Conversation Summary
The owner of a 1993 Mazda B2200 with a hydraulic clutch asked whether a slipping clutch can be adjusted and how difficult a full clutch replacement would be. Another user suggested checking pedal height and replacing the clutch with a manual and possibly a slave cylinder. A Mazda technician said a slipping clutch cannot be adjusted, the pedal should not be adjusted, and the transmission must be removed to replace the clutch, noting that removal is fairly easy on this truck.
