1990 Mazda RX7 Engine won't start
220,000 MILES • 6 CYL • 2WD • AUTOMATIC
MIKONIO
My problem is a bit of a two-parter. the main problem with my car is that it won't start. It's been having trouble turning over and catching, then staying on. I almost had it going when I let off the gas and it died on me. Since then, it seems my battery hasn't been able to keep a charge, even after being hooked up to a charger for half a day. I have since changed batteries, and blown my fuse with the new battery. My question is this. Do I have a lengthy, expensive problem with my car. I know that I need to get a new fuse, the main one, and I need to hook up my new battery. But after that, I'm not sure the problem of my car not starting will be resolved. It's been having trouble starting in the past. When I turn the key, sometimes it just makes a clicking noise without the engine turning over at all. After 3 or 4 turns of the key, it finally starts, but very softly. It also billows out quite a bit of white smoke, which makes me think that there is something either wrong my catalytic converter, my fuel filter, or something to do with my radiator as I've been having trouble with that lately. I have yet to buy a new fuse, I'm just curious as to what else I can do before taking it to a mechanic for a lengthy repair and stay.
Sep 26, 2009 at 2:58 PM
  • 75,988 POSTS
Find out what's causing the fuse to blow-when this done get the battery and alternator tested then proceed to do below
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
Sep 26, 2009 at 3:03 PM
