radiator i think...? :(
BRUTICE
  • 7 POSTS
hey there, i have a 1993 maza protege and im having some problems with my car overheating, not sure where exactily but there is a bubbling sound as if something is boiling everytime i drive my car somewhere, the sound seems to be comming from the anti-freez overflow tank, the onle thing that prevents it from doing that for a longer period of time is if i turn the heater on :s, not i cant exactily leave it on during the summer soo yeah if someone could get back to me asap i would verry much appreciate it, thanks!!
May 14, 2007 at 9:30 AM
  • 75,988 POSTS
[quote:e62161274b="Brutice"]hey there, i have a 1993 maza protege and im having some problems with my car overheating, not sure where exactily but there is a bubbling sound as if something is boiling everytime i drive my car somewhere, the sound seems to be comming from the anti-freez overflow tank, the onle thing that prevents it from doing that for a longer period of time is if i turn the heater on :s, not i cant exactily leave it on during the summer soo yeah if someone could get back to me asap i would verry much appreciate it, thanks!![/quote:e62161274b]
Replace the thermostat a cheap fix and then comeback or read below for your possibilities:
Try replacing the thermostat-not it do the following below:
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following: Thermostat,Clogged radiator,Fan clutch,Radiator electrical fan,collaspe hoses,water pump
Hope this help Good LUck
May 15, 2007 at 10:17 AM
