2001 Mazda Protege High-Speed Knock
Where is that knocking coming from the engine- Is it clacking, tapping or more like a thumping or bumping.
Can be a valvetrain, engine bearings, clogged oil galleries,and weak oil pump that the oil is not reaching all the way up.
Sometimes Doing an engine flush thouroughly might help.
What is the OBD2 code
Have the knock sensor check and ignition timing
HTH Good Luck!
Suggested Repair
At about 200,000 miles, diagnose the high-speed knock before assuming a rebuild. Identify whether it is tapping, clacking, or thumping, then retrieve the OBD2 code and check the knock sensor and ignition timing. Also consider valvetrain wear, engine bearings, clogged oil galleries, or a weak oil pump; a thorough engine flush may help if oil flow is restricted.
Conversation Summary
The owner of a 2001 Mazda Protege with about 200,000 miles says the engine runs well around town but knocks hard at high speed, with the check engine light coming on. A mechanic mentioned possible valve work but was uncertain. The expert says the mileage is near the point where an engine rebuild may be needed and asks for the knock's character and OBD2 code. Possible causes include valvetrain problems, bearings, clogged oil galleries, or a weak oil pump, and a thorough engine flush, knock-sensor check, and ignition-timing check are suggested.
