What is a G-signal
WAGSJL
1993 DOHC. Read the codes and came up with #3 distributor g-signal. I have already change spark plugs, wires and distributor rotor, and cap but still get code. can someone help me at what to look at and what is a g-signal? Thanks, wagsjl
Feb 21, 2007 at 8:53 AM
KIN CHAN
  • 453 POSTS
year, model, engine size please.
Feb 21, 2007 at 9:31 AM
WAGSJL
it is a 1993 DOHC.
Feb 21, 2007 at 9:41 AM
WAGSJL
can someone please help me with this?
I have tried to find out from about everyone including dealers what a distributor g-signal is, the car is a 1993 DOHC with a 1.8 engine and we have replaced the plugs, wires, cap, and rotor and still getting the check engine light with this code.
Please help.
Feb 23, 2007 at 8:49 AM
KIN CHAN
  • 453 POSTS
i thing g- signal is a rpm or cam signal from distributor to the ECM...either an input or acknowledgement signal to the computer..
Feb 23, 2007 at 12:08 PM
Good evening,
The ECM is not seeing a signal from the distributor for engine RPM. When this happens, the ECM will not allow spark or fuel.
You need a new distributor.
What usually happens is oil gets inside the distributor and the parts inside short out.
Mar 25, 2020 at 10:24 AM
