1998 Mazda Protege EGR Valve
ZEKE
I have a 1998 Mazda Protege LX, 1.5 L engine, 133000 mile. The check engine light came on and we were told the EGR valve and catalytic converter were going bad. Can the EGR valve be cleaned instead of buying one for nearly 500$?
Zeke
Feb 27, 2006 at 4:14 AM
COSMO
  • 347 POSTS
There is a good chance that you EGR valve is ok. What may have happened is the egr port to the egr boost sensor is clogged with carbon, this is usually fixxed by having your intake taken off and having all the egr ports cleaned out. NOTE! These ports cannot and will not be cleaned out by any 'intake' cleaners in a can. Sorry but thems the brakes.
Cosmo...Mazda Tech
Feb 27, 2006 at 2:41 PM
Suggested Repair
Remove the intake manifold and clean carbon from all EGR ports, especially the port to the EGR boost sensor. Aerosol intake cleaners will not clear these ports. The EGR valve itself may be fine.
Conversation Summary
The owner of a 1998 Mazda Protege LX 1.5L with 133,000 miles has a check engine light and was told the EGR valve and catalytic converter were failing. They asked if the EGR valve could be cleaned instead of replaced. A Mazda technician said the valve is often fine and the usual problem is carbon clogging the EGR port to the EGR boost sensor, which requires removing the intake and cleaning the EGR ports. Canned intake cleaners will not clear those ports.
