1998 Mazda Protege AC Stops When Hot
GMJOHNSON99
My air conditioner in my 1998 Mazda Protege works intermittantly, it stops working when the outside air temperature is about 80 degrees or warmer. I have had this problem for over a year now, does anyone know what the problem could be?
Apr 16, 2006 at 12:07 PM
LOSONE
  • 1,616 POSTS
Yup, it needs some R-134A. It will probably take one 12 oz can to correct the problem. You can get a recharge can with oil, dye with the gauge from the Zone for $24.95 Good luck
Apr 16, 2006 at 12:59 PM
Suggested Repair
Recharge the A/C with about one 12 oz can of R-134A, preferably a can that includes oil, dye, and a gauge.
Conversation Summary
The owner of a 1998 Mazda Protege reports intermittent A/C that stops working when the outside temperature is about 80 degrees or warmer. The expert says the system likely needs R-134A and that one 12 oz can with oil, dye, and a gauge should correct it.
