1995 Mazda Protege AC Blows Hot
GMAND
I have a 1995 mazda protege. The air conditioning intermittintly works. If the car is cooled down and it is relatively cool outside it works fine. However once the car has heated up and/or it is hot outside, the air conditioner just blows hot air, occasionally blowing cold air - but cycling back to just blow hot air. I have had it recharged (or at least they told me it was recharged). Any help would be appreciated.
May 23, 2006 at 3:29 PM
SDALTON19
  • 87 POSTS
need more information after you had it recharged did it work fine for a day or so and then start doing the same thing or did it do the same thing all the time if it worked fine for a day or so then you probabley have a leak and that needs to be repaired. if thats not the case does it cool well while driving on the highway but not when your stoped if thats the case then your ac condensor fan is not functioning more than likeley but like i said would have to have more information i hope this helps
May 25, 2006 at 4:27 PM
GMAND
Thanks sdalton for replying. It seems like it worked fine for about a week. I took it back into where they recharged it - but they said everything looked fine. I was frustrated with them because they had no answers, when it clearly wasnt working so I left. Now I am trying once again to figure this out.
Thanks for any help you have.
May 29, 2006 at 9:30 AM
Suggested Repair
Because the AC worked for about a week after a recharge and then failed again, a refrigerant leak is likely. Have the leak found and repaired, then recharge the system. If cooling fails mainly when stopped but works on the highway, also check the AC condenser fan.
Conversation Summary
The owner of a 1995 Mazda Protege reported intermittent AC that blows hot air once the car or outside air is hot, despite a recharge. The expert said a leak is likely if it worked briefly after charging, and a failed condenser fan is more likely if it cools on the highway but not when stopped. The owner confirmed it worked for about a week after the recharge, then failed again, and the shop found nothing.
