1999 Mazda Protege a/c not working
1999 MAZDA PROTEGE
120,000 MILES • 4 CYL • 4WD • AUTOMATIC
KLMAIA
My 99 Mazda protege a/c was working fine. One day while driving I heard a loud noise coming from the passenger side of the vehicle and the a/c vents started smoking and stopped working. Now when I try to turn it on (on levels 1, 2, and 3) nothing happens yet the a/c green light stays on. On level 4 the green light turns off and air blows out...not cold air though. Same thing happens on heat except on level 4 hot air does blow out. Also, it is very loud on level 4. Any ideas what the problem could be? cost of fixing? Tips on how I can check it out or fix it myself would be helpful. By the way, I know very little about cars.
Dec 11, 2009 at 1:07 PM
  • CERTIFIED EXPERT
Hi klmaia and TY for the donation
Sir/Madam if you're not electrically incline, you might to have to take in, electrical problems can be a nightmare to deal with
Check the AC fuse 25amp and the heater fuse40 amp if okay -do below
Find the blower motor resistor behind right side of dash and replace it, then get back with me asap. As for the costs it varies with location that parts and labor rates
Dec 11, 2009 at 4:27 PM
