2002 Mazda Protege squealing noise
88,000 MILES • 4 CYL • FWD • AUTOMATIC
JOSEPH SWARTZ
changed fan belts, checked altenator,power steering,
and compessor pullies for bad bearings. Problem is the
belts squeals at eractic times. First starting up or traveling 65mph down the hwy. Last only 15 to 30 seconds. Had my mechanic check it out and found nothing wrong. Is there something else to check or could it be something else that may sound like a belt
slipping.
Jan 27, 2008 at 10:11 AM
  • 75,988 POSTS
Belt squeals-if its not coming from a bearing-I'll recheck the drivebelts tension its probably still loose
Jan 28, 2008 at 5:20 AM
GLENDAB
I have a 1999 mazda protege se it developed a squeal on one of the belts,I tried several suggestions,in the end I noticed dirt had built up in the groves on the pulleys,cleaned the grooves and the squeal went away.
May 13, 2009 at 4:31 AM
