Oil leak at Rear main seal
MAZDA
ADU
  • 15 POSTS
An oil leak diagnostic test done at a popular mechanic shop has revealed a leak at the rear main seal.
The mechanic shop recommends replacing the seal, the cost of which is $500.
Is this a DIY activity?
Are there any alternative solutions to this problem like oil additives which stop leaks? If yes how effective are they?
Thanks,
adu
Jan 4, 2007 at 11:46 AM
SERVICE WRITER
  • 9,123 POSTS
You may have to pull the tranny to get to it, are you capable?
If you figure a seal is $20.00 and the rest is tax and labor, that puts it about 6 hours to do the job for a pro. That's quite a few snicker bars :)
D-I-Y is purely specific to the individual.
Don't use an additive that plugs leaks or you''ll plug more than a leak.
Jan 4, 2007 at 12:40 PM
COSMO
  • 347 POSTS
What engine and vehicle is it that you have. The answer may lay in the information you give me.
Cosmo...Mazda TEch
Jan 4, 2007 at 12:54 PM
ADU
  • 15 POSTS
Mazda 626 V6 - 1995
136000 miles.
I chk the oil levels even more regularly now.
I am not losing oil significantly.
How long can I live with this problem safely?
What other problems could this lead to?
Thanks,
adu
Jan 4, 2007 at 1:54 PM
