Mazda External Transmission Cooler
MAZDA
ADU
  • 15 POSTS
I have browsed the internet and have read a lot about the transmission problems with Mazda vehicles.
I also read an interesting article in which the writer suggests installing an external transmission cooler to protect the transmission system.
How effective is this precaution and is it cost effective?
Also, where could you get this done? (I have checked with Pep boys and they dont do it)
Thanks,
adu
Jan 4, 2007 at 11:39 AM
  • 75,988 POSTS
Its a wise idea for future use on towing purposes-your present radiator can do the job for normal usage-best preventive maintenance is to keep track with the fluid and filter normal or severe conditions. The same thing with oil change, not maintain wiil produce sludge and reduces engine life.
Back in my youngen days-when i change oil, I also change the tranny. You know am done there, might as well do both.My limit is 2500 miles then out she goes.
Jan 6, 2007 at 8:19 PM
Suggested Repair
For normal driving, the existing radiator transmission cooler is adequate. An external cooler is mainly worthwhile for towing. Prioritize regular transmission fluid and filter service according to normal or severe-use conditions.
Conversation Summary
A Mazda owner asked whether an external transmission cooler is effective and cost-effective, and where it could be installed. The expert said the current radiator cooler is sufficient for normal use, while an external cooler is a good idea for towing. Regular fluid and filter maintenance was recommended as the best prevention.
