1995 Mazda Millenia Misfire
1995 MAZDA
CIPRO
I have a 95 Millenia S with a MC engine with 140,000 miles that will run on 5 cly from time to time. We replaced the #2 injector last week and it ran great for a short time. Now it is acting up again. The CE is on but when I jump Grd and 10 no codes are present. Could it be a bad coil pack on #2. Help
Oct 27, 2007 at 9:22 AM
BMRFIXIT
  • 19,053 POSTS
[quote:963c735791="Cipro"]I have a 95 Millenia S with a MC engine with 140,000 miles that will run on 5 cly from time to time. We replaced the #2 injector last week and it ran great for a short time. Now it is acting up again. The CE is on but when I jump Grd and 10 no codes are present. Could it be a bad coil pack on #2. Help[/quote:963c735791]
It’s so easy to guess (is it this or that)
But can be very expensive too
So how about running some tests and checking for a cause
1st check if you have spark on that cylinder and
If the spark strong! If the wire ok and the plug and or the coil
2nd do a compression test
3rd check the wiring on the injector is it pulsing
see if you can get the codes i thing 95 is obd2 ready
Good luck
Let us know
Oct 27, 2007 at 10:40 AM
Suggested Repair
Do not replace parts by guesswork. On the misfiring cylinder, verify strong spark and inspect the plug, wire, and coil; perform a compression test; confirm the injector wiring is pulsing; and retrieve diagnostic codes, noting a 1995 model may be OBD-II capable.
Conversation Summary
A 1995 Mazda Millenia S with the MC engine and 140,000 miles intermittently runs on five cylinders. Replacing the number 2 injector helped briefly, then the problem returned. The check-engine light is on, but jumping ground and terminal 10 produced no codes. The owner suspects the number 2 coil pack. The expert recommends testing spark strength, the plug, wire, and coil, checking compression and injector pulse, and retrieving codes rather than guessing.
