1993 Mazda MX6 Thermostat Location
  • 75,988 POSTS
Need location on the Stat
TIA
Feb 2, 2007 at 7:44 PM
COSMO
  • 347 POSTS
4cyl is on the block at the lower rad hose under the exhaust manifold.
v6 is also on the lower rad hose at the back of the left side cyl head. Requires the removal of the air box.
Cosmo...Mazda TEch
Feb 3, 2007 at 12:17 AM
  • 75,988 POSTS
[quote:dc35011cef="Cosmo"]4cyl is on the block at the lower rad hose under the exhaust manifold.
Cosmo...Mazda TEch[/quote:dc35011cef]
Thank You MR. Cosmo
Feb 3, 2007 at 7:01 AM
Suggested Repair
Locate the thermostat on the lower radiator hose. On the 4-cylinder it is on the block under the exhaust manifold. On the V6 it is at the back of the left cylinder head and the air box must be removed.
Conversation Summary
The owner of a 1993 Mazda MX6 asked where the thermostat is located. An expert said the 4-cylinder thermostat is on the block at the lower radiator hose under the exhaust manifold, and the V6 thermostat is on the lower radiator hose at the back of the left cylinder head, requiring air box removal. Another participant thanked the expert.
