Mazda MX6 wheel bearing 1990 2.2ltr
1990 MAZDA MX5
TONYGTHREE
How do you remove the front wheel bearing after you remove the caliper, rotor ansd axle nut.
It does not appear as there is a bearing housing that comes off.
Feb 8, 2007 at 2:45 PM
COSMO
  • 347 POSTS
You have to remove the entire spindle from the strut and the lower control arm. Then you will have to press the bearing out/in, plus you will have to remove part of the bearing race that will be stuck on the axle hub when it is pressed out.
These bearing are NOT an easy bolt on.
You will need to buy a new: bearing, axle nut, lower ball joint 'pinch bolt' and a new seal for behind the bearing.
Cosmo...Mazda TEch
Feb 8, 2007 at 9:59 PM
