My drivers side window will only go up 1/4 way and then stops. If I press the button up and down eventually it stops working all together. The repair shop said it might be the motor but they will have to open the door up to check.... if it is the motor is this an easy repair for my husband - he did previously replace the window motor on his 1991 Mazda Miata when it died? Also..... does it make a signifigant difference using Certified Mazda Parts as compared to aftermarket parts??? The aftermarket parts seem to be at least 1/2 price of Mazda parts. Thanks! Colleen
Oct 24, 2008 at 11:46 PM
