1998 Mazda MPV 4WD Stuck
XVIERA31
:x I HAVE A 98 MAZDA MPV THAT WAS RUNNING GOOD UP UNTILL 3 DAYS AGO, MY HUSBAND ACTIVATED THE 4WH DR AND I TURNED IT OFF ACCIDENTALLY WHILE DRIVING IT, NOW THE 4WHL DR IS STUCK AND WON'T DISENGAGE, IT MAKES A LOUD CLANKING NOISE EVERY TIME I TAKE A TURN, WE TRIED TO TAKE IT OFF THE 4WHL DR BUT IT REFUSES TO BUDGE ON THE 2WH DR. WHAT CAN WE DO AND A BOUT HOW MUCH WILL IT COST TO FIX THIS PROBLEM? :oops:
May 18, 2006 at 11:47 AM
SDALTON19
  • 87 POSTS
well it sounds like damage has been done to the transfer case you have 2 options either take it to a transmission shop and have it fixed or take out the front drive shaft and dont use the 4 wheel drive i hope this helps
May 25, 2006 at 4:44 PM
Suggested Repair
Have the transfer case inspected and repaired at a transmission shop. As a temporary option, remove the front driveshaft and do not use four-wheel drive.
Conversation Summary
The owner of a 1998 Mazda MPV said four-wheel drive was switched off while driving and is now stuck engaged, with a loud clanking noise during turns and no response when selecting two-wheel drive. The expert said the transfer case may be damaged and recommended either a transmission shop repair or removing the front driveshaft and not using four-wheel drive.
