1993 Mazda B2200
AERIC
  • 1993 MAZDA B2200
  • 4 CYL
  • MANUAL
  • 300,000 MILES
When I try to start my truck, it dosent start at all. I get the ignition but I cant give it gaz
Sunday, November 8th, 2009 AT 2:14 PM
If its cranking over and will not start do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Sunday, November 8th, 2009 AT 2:45 PM
