I know where the clamp is to take off so I can flush the radiator out, but how do I take it off and when I do, how do I put it back on?
Nov 3, 2007 at 1:20 PM
MERLIN2021
✓ASE Certified Mechanic
To drain the radiator look at the bottom and find the drain cock, it's usually white plastic and looks like a bolt, then drain the old coolant, refill with water and the flush formula of your choice, follow the manufacturer's directions, then re drain and fill with 50/50 mix!
Nov 3, 2007 at 1:51 PM
