white smoke??
CAROWNER82406
I have a 92, v6, Mazda 929, it has about 133,000 miles on it.. the problem i am having is alot of white smoke coming from the exhaust, and when i press on the gas there's what looks like a spurt of water coming out. Ive checked the oil, trans fluid, and radiator fluid and nothing appears to have a milky color to it. Along with it occasionally overheating, it's also making a knocking sound...what could be the problem?
Nov 11, 2007 at 10:00 AM
  • 75,988 POSTS
Could be the headgasket is blown or crack head or block get it tested see below
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following: Thermostat,Pressure test the Rad. cap,Clogged radiator,Fan clutch,Radiator electrical fan,collaspe hoses,water pump.
Good Luck
Nov 11, 2007 at 10:04 AM
