1962 Mazda 626 Will Not Start
LEXIEAUSXX
[color=green][/color]
Dec 28, 2006 at 2:19 PM
  • 75,988 POSTS
Does it crank over or cranks over and w/n start or cranks, runs and then stall.
Dec 28, 2006 at 9:16 PM
LEXIEAUSXX
well, today it started then stalled straight away, i tried it again and it wouldnt start at all, i left it a few hrs then it started, i reversed it then it stalled again, i tried to start again and nothing
Dec 28, 2006 at 10:28 PM
ROBCHOP
[quote:7534dac5f6="lexieausxx"]well, today it started then stalled straight away, i tried it again and it wouldnt start at all, i left it a few hrs then it started, i reversed it then it stalled again, i tried to start again and nothing[/quote:7534dac5f6]
same problem!! please help!
Nov 26, 2007 at 10:54 AM
  • 75,988 POSTS
Mazda 626 Repair Question
What engine liter-start by check the fuel pressure if that's okay. Start at the idle air conrol valve take it out and clean it and check the throttle position sensor's closed and wide open throttle voltages
Try this first look for an exhaust restriction -to rule out the catalytic converter
Nov 26, 2007 at 3:22 PM
Suggested Repair
Check fuel pressure first. Remove and clean the idle air control valve, and verify throttle position sensor voltage at closed and wide-open throttle. Also inspect for an exhaust restriction to rule out a clogged catalytic converter.
Conversation Summary
The owner reported a Mazda 626 that started, stalled immediately, then would not restart. After sitting a few hours it started again, stalled while reversing, and then would not start. Another user reported the same symptom. The expert advised checking fuel pressure, cleaning the idle air control valve, checking throttle position sensor voltages, and looking for an exhaust restriction such as a restricted catalytic converter.
