1998 Mazda 626 No Start Fuel Pump
BDES64
Ny 98 626 4cyl. is having problems starting. The Haynes Manual says check (jump pins) on the fuel pump relay. I can not find this in the manual. Under the hood next to the black fuse/relay bos are three grey relays. I am assuming it is one of these. I can not find out what any of these three are in the manual. Please help.....
Oct 23, 2006 at 12:18 PM
COSMO
  • 347 POSTS
If I remember correctly it is either the one closest to the driver fender or the middle one, but not sure at this time. What kind of trouble is your car giving you as far as hard to start?
You might be on the right track though as fuel pumps were not uncommon on those years of 626.
Cosmo...Mazda Tech
Oct 24, 2006 at 2:57 PM
BDES64
It was running fine and one day it seems I lost power and now it will not start. I have checked alll 4 cyl for spark, checked the coil pack. put in a new fuel fiilter. I do not hear the fuel pump truning on??I THINK. It is hard to hear.. THanks
Oct 25, 2006 at 12:57 AM
COSMO
  • 347 POSTS
yah it is hard to hear. Take the top fuel line off the fuel filter and get someone to crank the engine. Is there fuel coming out of the filter? If not you have something either wrong with the wiring to the pump or the pump itself. Also check the EGI fuse in the fuse box under the hood
Cosmo...Mazda Tech
Oct 25, 2006 at 4:24 AM
BDES64
[quote:913aebbaf2="Cosmo"]yah it is hard to hear. Take the top fuel line off the fuel filter and get someone to crank the engine. Is there fuel coming out of the filter? If not you have something either wrong with the wiring to the pump or the pump itself. Also check the EGI fuse in the fuse box under the hood
Cosmo...Mazda Tech[/quote:913aebbaf2]
That egi fues is impossible to find here..Can I check it with a meter..It is a relay correct..??Thanks
Bruce
Oct 26, 2006 at 7:26 AM
Suggested Repair
With the top fuel line removed from the fuel filter, have someone crank the engine and check whether fuel comes out. If none does, suspect the fuel-pump wiring or the pump itself. Also check the under-hood EGI fuse. The fuel-pump relay may be the gray relay nearest the driver-side fender or the middle one, but that location was not confirmed.
Conversation Summary
A 1998 Mazda 626 4-cylinder lost power and will not start. The owner confirmed spark and the coil pack, replaced the fuel filter, and could not hear the fuel pump or identify the fuel-pump relay among three gray relays. The technician said the relay might be nearest the driver fender or in the middle, but was unsure. The recommended checks were to disconnect the top fuel line at the filter and look for fuel while cranking, then inspect the under-hood EGI fuse. If no fuel appears, the pump wiring or pump itself may be at fault. The owner's follow-up about testing the EGI fuse with a meter was not answered.
