1993 Mazda 626 No Fuel Pump Power
TSIMONSEZ
1993 mazda 626 four cylinder Im looking for a fuse that power my fuel pump it not coming on i changed out the fuel pump and check all fuses none say fuel pump i check fuses inside the car and under the hood.The car will turn over but want start
Aug 18, 2007 at 2:28 PM
  • 75,988 POSTS
[quote:a5eb378bbc="tsimonsez"]1993 mazda 626 four cylinder Im looking for a fuse that power my fuel pump it not coming on i changed out the fuel pump and check all fuses none say fuel pump i check fuses inside the car and under the hood.The car will turn over but want start[/quote:a5eb378bbc]
You are probably looking for the fuel pump relay its in the engine compartment in the fuse/relay block.
Aug 18, 2007 at 10:39 PM
Suggested Repair
Check the fuel pump relay in the engine compartment fuse and relay block, since the pump circuit may not be labeled as a fuel pump fuse.
Conversation Summary
The owner of a 1993 Mazda 626 four-cylinder says the engine cranks but will not start and the fuel pump does not come on. The pump was replaced and the interior and under-hood fuses were checked, but none were labeled fuel pump. The expert advised looking for the fuel pump relay in the engine compartment fuse and relay block.
