Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mazda
626
Fuel System
Fuel Pump
Replace/Remove
1990 Mazda 626 REplace feul pump
1990 MAZDA 626
88,000 MILES • 4 CYL • FWD • AUTOMATIC
TNJ1982
MEMBER
replaced feul pump getting gas to engine but it will not stay running will crank then die. it is like it is not getting gas.
Apr 9, 2010 at 9:46 AM
Experienced Mechanic
Though its new check the fuel pressure if its within specs and also test the main relay
Apr 9, 2010 at 9:59 AM
TNJ1982
MEMBER
where is the main relay and how do you check the fuel pressure?
Apr 9, 2010 at 10:04 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
