2000 Mazda 626 Floods No Start
MARLANMESTRY
2000 MAZDA 626 SA MODEL
WHEN I START THE CAR IT TURNS BUT NO IGNITION. I TOOK OUT THE PLUGS AND ALL HAVE FIRE, BUT THE CYLINDERS ARE FLOODED. WE HAVE CHECKED FUEL REGULATOR AND ITS AT 2.5 BARS, CODES WHERE SCANNED BY A COMPUTER AND NO FAULTS WHERE FOUND. THE CAR KEEPS FLOODING.PLEASE HELP
Feb 15, 2007 at 9:17 PM
JOSEPH STELLMAN
1990 masda626 doesnt heat up or cool off real well when i bought the car it had 112,000 miles the mechanic who sold it to me pointed out a small fan that didnt work in the front of the vehichle said i could probably find a replacement at a junk yard, would like to fix the problem
Feb 25, 2007 at 4:02 AM
  • 75,988 POSTS
[quote:740536b812="marlanmestry"]2000 MAZDA 626 SA MODEL
WHEN I START THE CAR IT TURNS BUT NO IGNITION. I TOOK OUT THE PLUGS AND ALL HAVE FIRE, BUT THE CYLINDERS ARE FLOODED. WE HAVE CHECKED FUEL REGULATOR AND ITS AT 2.5 BARS, CODES WHERE SCANNED BY A COMPUTER AND NO FAULTS WHERE FOUND. THE CAR KEEPS FLOODING.PLEASE HELP[/quote:740536b812]
Check the coolant temperature sensor.
Feb 25, 2007 at 6:15 AM
Suggested Repair
Check the coolant temperature sensor, which can cause a rich mixture and flooded cylinders if it is reading incorrectly.
Conversation Summary
A 2000 Mazda 626 cranks with spark at the plugs but will not start because the cylinders are flooded. Fuel pressure was about 2.5 bar and a scan found no fault codes. The expert recommended checking the coolant temperature sensor. A separate note about a 1990 Mazda 626 cooling fan was not addressed.
