1996 Mazda 626 No Start After Sitting
SCHOULTZD
  • 5 POSTS
I have a 1996 Mazda 626 DX 4-cyl. which on occasion will not start. It seems to occur when it sits over the weekend. I have changed the fuel filter hoping that was the problem, but it did it again this AM. It could be a sensor, but I don't know where to start. After it does start it runs fine, except a possible hesitation that is so minor that I cannot be sure that is what it is.
Jan 22, 2007 at 7:11 AM
MWHITNEY
  • 63 POSTS
is there any codes stored in the ecm?
Jan 22, 2007 at 11:18 PM
SCHOULTZD
  • 5 POSTS
Not too sure doing that today. It started this AM after not starting yesterday at all. Thank you for your help in this matter.
Dan
Jan 23, 2007 at 2:51 AM
  • 75,988 POSTS
[quote:595093f838="schoultzd"]I have a 1996 Mazda 626 DX 4-cyl. which on occasion will not start. It seems to occur when it sits over the weekend. I have changed the fuel filter hoping that was the problem, but it did it again this AM. It could be a sensor, but I don't know where to start. After it does start it runs fine, except a possible hesitation that is so minor that I cannot be sure that is what it is.[/quote:595093f838]
When was the last tune-up? also you can inspect and test the coolant temperature sensor
Jan 23, 2007 at 6:49 AM
SCHOULTZD
  • 5 POSTS
I will have that checked. The last tune up was a while ago. I appreciate all your help and willl update as soon as I do the steps you suggest
Jan 23, 2007 at 8:15 AM
ROBCHOP
[quote:42f47de7c5="schoultzd"]I will have that checked. The last tune up was a while ago. I appreciate all your help and willl update as soon as I do the steps you suggest[/quote:42f47de7c5]
i have the saaaaame problem please HELP!
Nov 26, 2007 at 10:53 AM
Suggested Repair
Check when the last tune-up was done and inspect and test the coolant temperature sensor.
Conversation Summary
The owner of a 1996 Mazda 626 DX reports an occasional no-start after the car sits, especially over a weekend. Replacing the fuel filter did not fix it, and the engine runs fine once started, with only a possible slight hesitation. A user asked whether ECM codes were stored, but none were confirmed. An expert asked about the last tune-up and recommended inspecting and testing the coolant temperature sensor. The owner planned to follow those steps, but no results or confirmed repair were reported.
