1993 Mazda 626 Shakes When Accelerating
JENI
I have a 93 Mazda 626, 5 speed. It has had a new fuel pump, distributor, and axels in the last year . The day after my axel was fixed it started to shake when accelerating. It is much worse when going uphill. I am afraid it is the transmission as it has slipped out of 5th a couple times. Does one relate to the other or could they be 2 separate things. I also thought the shaking might be from the axel repair needing an adjustment. Any ideas????
Jun 12, 2006 at 2:51 PM
SYNCRAIT
  • 235 POSTS
is the shaking coming from the engine or more to the sides of the front end....at night start the car and look under the hood at the plug wires and see if you can see little flashes coming off them possibly arcing to the valve cover or something also check the ignition coil wire.... you just might need to replace the wires.... good luck :)
Jun 12, 2006 at 11:36 PM
Suggested Repair
Check whether the shake comes from the engine or the front end. At night, inspect the spark plug wires and ignition coil wire for arcing, and replace the wires if they flash or arc.
Conversation Summary
The owner of a 1993 Mazda 626 manual reports shaking during acceleration, worse uphill, starting the day after an axle repair. Recent work also included a fuel pump and distributor, and the transmission has slipped out of fifth a couple of times. The expert asks whether the shake is from the engine or the sides of the front end and recommends checking the plug wires and coil wire for arcing, which may require wire replacement.
