1994 Mazda 626 Shakes Under Load
CHZUCK
I have a 1994 Mazda 626 with 2.0 engine with 204k. When on the highway at 55 up through 70 the front of the car shakes when under light load (when going up a slight grade). Strange, but it does not seem as bad at 75. Light load, light shake, heavier load, heavier shake - the more you press on the gas the worse the shake. On the level it is OK. I changed plugs and wires, checked cap and rotor - looked fine. Checked resistance on the primary and secondary windings of the coil - OK per shop manual specs. Should I change the coil even though it checked OK? Should I replace the cap and rotor even though they look fine?
I have checked for fault codes and there are none. This problem is not noticeable on back roads and in town driving, only highway driving.
Apr 21, 2007 at 3:09 PM
2CARPRO JACK
  • 11,533 POSTS
Wheel balance all good, have the front end inspected, could be axles or wheel bearings as long as the engine runs good
Apr 23, 2007 at 12:34 AM
CHZUCK
Thanks for the help. I will take a close look at the front end.
Apr 24, 2007 at 5:05 AM
Suggested Repair
Confirm the wheels are balanced and have the front end inspected, focusing on the axles and wheel bearings if the engine is running well.
Conversation Summary
The owner of a 1994 Mazda 626 with a 2.0 engine reported front-end shaking at highway speeds under load, especially on slight grades, while level driving was normal. Ignition parts, coil resistance, and fault codes had already been checked without finding a cause. The expert advised confirming wheel balance and inspecting the front end, including the axles and wheel bearings, provided the engine runs well. The owner planned to inspect the front end.
