1999 Mazda 626 MAF and O2 Sensor Location
ATTILAKILLA1
I just recently bought a 99 mazda 626, I had it taken to autozone for a diagnostic test. I was told that I had codes reading a failed Air mass sensor and both of my oxygen sensor were blow. The car has 160,000 miles on it and it an automatic tranmission. I know that both of these item need changing around 100,000 miles. My problem is that I can't find the air mass sensor and the oxygen sensor. Can you please help me out. I was planning to replace this stuff on my own. Just show me in the right direction.
Sep 9, 2007 at 5:47 AM
FAIRRACING31
  • 150 POSTS
The Mass Airflow (MAF) sensor is located in the air intake duct. That is the part that goes from your airfilter box, to you throttle body. The sensor uses a hot wire sending element or potentiometer, depending on model, to measure the amount of air entering the intake system. It sends this info to the PCM as a voltage signal, which in turn, calculates the required fuel injector pulse width.
The Oxygen sensor (O2S) , the primary O2 is located in the exhaust manifold or pipe before the catalytic converter. The secondary O2 is located in the exhaust pipe after the catalytic converter, follow the harness to locate the connector. The O2 moniters the oxygen content of the exhaust gas stream. The oxygen content in the exhaust reacts with the O2 sensor to produce a voltage output which varies from 0.1-volt (lean) to 0.9-volt (Rich). The PCM constantly moniters this variable voltage output to determine the ratio of oxygen to fuel mixture. Which is also controlled by the injector pulse.
Oct 21, 2007 at 8:55 AM
Suggested Repair
Locate the MAF sensor in the intake duct between the air-filter box and throttle body. The primary oxygen sensor is in the exhaust manifold or pipe before the catalytic converter; the secondary sensor is in the exhaust pipe after the converter. Follow each sensor harness to its connector.
Conversation Summary
The owner of a 1999 Mazda 626 with 160,000 miles was told a scan showed a failed mass airflow sensor and both oxygen sensors, and asked where those parts are so they could be replaced. The expert explained that the MAF is in the intake duct between the air filter and throttle body, the primary oxygen sensor is before the catalytic converter, and the secondary sensor is after it.
