2002 Mazda 626 Re:Overheating
161,000 MILES • 4 CYL • 4WD • AUTOMATIC
KIMBERLYWYATT4
My car is overheating. It has antifreeze in it.
Apr 5, 2010 at 9:30 AM
LEGITIMATE007
  • 5,121 POSTS
are you assuming its overheating because that is what the temp gauge says? or is the vehicle like popping the radiator cap off and steam is coming out.
Apr 6, 2010 at 11:20 PM
KIMBERLYWYATT4
The car is overheating the temperature gauge is all the way past the H. It will cut off when it is at the H. There is no steam coming from it.
Apr 7, 2010 at 12:39 AM
LEGITIMATE007
  • 5,121 POSTS
ok that is a safety cutoff switch, so it doesnt do additional damage to the engine. we need to establish if the radiator fan is coming on, by hardwiring it to the battery., then we must check the engine coolant temp sensor, if the fan works. because the car may not be actually overheating, it could be a wrong signal from a faulty engine cooant temp sensor. of course, before doing all of this we need to make sure we have enough coolant in the system.
Apr 7, 2010 at 1:44 AM
KIMBERLYWYATT4
The fan does come on and there is coolant in the radiator.
Apr 7, 2010 at 2:18 AM
