2002 Mazda 626 Engine overheating when a/c unit is running
80,000 MILES • 6 CYL • 4WD • AUTOMATIC
MIRI01
I purchased a used 2002 Mazda 626 about 1 year ago and recently it has been overheating when the a/c unit is used. I replaced the water resevior which had a crack in it and there are no leaks from radiator, what could be the cause of this?
Jun 19, 2008 at 11:18 AM
KHLOW2008
  • 41,812 POSTS
Hi miri01,
Are the radiator and condenser fans working?
Did you check the coolant level in the radiator?
If yes to both the above, you might have a weak water pump, partially stuck thermostat, clogged coolant passage or radiator.
Jun 22, 2008 at 4:44 AM
