2002 Mazda 626 car is over heatin
122CASSIE
  • 2002 MAZDA 626
Engine Cooling problem
2002 Mazda 626 4 cyl Front Wheel Drive Automatic
My car is over heating and when u put water in it it is coming out as fast as u put it in on the driver side is where I notice the leaking
Thursday, August 19th, 2010 AT 8:32 AM
  • 31,937 POSTS
Hi there,
West need to positively identify this leak, if you get a cooling system pressure test done, a mechanic can tell you where the leak is, but if you cant drive it as it is loosing to much coolant, fill the radiator and watch carefully and see if it is a hose leaking, this is the most common cause, have a look and see if you can spot anything and report back what you see.
Mark (mhpautos)
Thursday, August 19th, 2010 AT 8:37 AM
