2000 Mazda 626 Jerks at 2000-3000 RPM
BR3TTV
Hi
I have a weird problem.
My car drives fine at revs 0-2000 then jerks between 2-3000 revs then is fine? (Feels like its starved of fuel or that the plugs arent firing?)
Has anyone else had this problem?
Thanks
Brett
Feb 13, 2007 at 8:02 PM
  • 75,988 POSTS
[quote:c884a027ba="Br3ttv"]Hi
Thanks
Brett[/quote:c884a027ba]
Check your ignition timing-also the Throttle position sensor/MAP or air flow meter and last the fuel pressure.
How new is the fuel filter
Apr 2, 2007 at 6:12 PM
Suggested Repair
Check ignition timing, the throttle position sensor, MAP sensor or airflow meter, and fuel pressure. Also check the age and condition of the fuel filter.
Conversation Summary
The owner of a 2000 Mazda 626 reports that the car drives fine below 2000 rpm, jerks between 2000 and 3000 rpm, then runs fine again, feeling like fuel starvation or misfiring plugs. The expert recommends checking ignition timing, the throttle position sensor, MAP sensor or airflow meter, and fuel pressure, and asks how new the fuel filter is.
