1998 626 Stutters After Engine Wash
Suggested Repair
Check electrical connectors for moisture after the engine wash, starting with the fuel injector connectors, and dry any wet connections.
Conversation Summary
The owner of a 1998 Mazda 626 said the engine began stuttering under acceleration and struggled to gain speed after the engine was washed. It had run normally for about 10 miles, then the problem started after the car sat for about half an hour and was still present 24 hours later. The spark plug wires and encapsulated coil were dry. The expert said moisture could be in almost any connector and suggested checking the injector connectors. Other participants said water can enter a distributor during washing and suggested drying the cap, spraying it with silicone before washing, and using an oil-based product such as WD-40 if the inside is wet, while avoiding high engine speed if moisture is present.
