Engine Performance problem
1994 Mazda 626 4 cyl Two Wheel Drive Manual
It has a regular engine miss and has failed cylinder #2 no change when you move the plug. The sparks plug are new. The RPM are seesaw when decelerate
Wednesday, August 25th, 2010 AT 12:16 PM
DOCFIXIT
MECHANIC
Check engine compression post will advise
SPONSORED LINKS
Wednesday, August 25th, 2010 AT 1:46 PM
ANEL
MEMBER
Compression is well, fine good
A interruption of continuous power during acceleration (HESITATE). When decelerate the RPM is seesaw. And then stabilizes or stall
