2002 Mazda 626 Stalls After Misfire
COLETTE MILLER
Spark plugs and wires were changed 3 months ago.....check engine light came on and car was stalling and would hesitate...took to autozone and they checked with instrument under dash....code read "misfiring"....checked gapping.......ran fine....then stopped running.....changed spark plugs to pregapped plugs....(expensive).....checked wiring....car will start and drive briefly, but will stall, stop and not restart......checked coil pack and car started, stalled and will not restart....also found oil on second plug and looked a little burnt....what could be the problem?
May 1, 2006 at 3:42 AM
LOSONE
  • 1,616 POSTS
It cold be a fuel problem. Have you checked the injectors to see if they are all "clicking" the same? DON'T use zone or other cheap wires on that engine. Use good solid parts not discount parts.
May 1, 2006 at 7:19 AM
Suggested Repair
Check that all fuel injectors click the same and investigate a possible fuel delivery problem. Use quality spark plug wires rather than discount parts.
Conversation Summary
The owner of a 2002 Mazda 626 reported a check engine light, hesitation, stalling, and a misfire code after recent spark plug and wire replacement. The car starts briefly, then stalls and will not restart; oil was also found on the second plug, which looked slightly burnt. An expert suggested a possible fuel problem, checking that all injectors click the same, and using quality wires instead of discount parts.
