how do i remove the cv joints on my mazda 323 1987.front whell drive 5 speed.
Mar 16, 2006 at 1:18 PM
Remove the wheel and move the hub out of the way, dropping the A-frame if needed. Pull the CV shaft straight out with a firm tug. To reinstall, align the splines and push the shaft firmly into place. Also replace the transmission input seal and the inner wheel seal to help prevent leaks.
The owner of a 1987 Mazda 323 front-wheel-drive 5-speed asked how to remove the CV joints. Advice was to clear the wheel and hub, possibly drop the A-frame, and pull the shaft straight out. Reinstallation requires aligning the splines and pushing the shaft in. Replacing the transmission input seal and inner wheel seal was also recommended to reduce leak risk.
