LS leaking oil
90,000 MILES
CAMANOPENNY
LS is leaking oil. I went underneath to find the source. I observed there was a small drip on the filter. Also, I noticed that there appears to be a bolt missing on the oil pan. I am not sure if this is supposed to have a bolt or not. The missing bolt is on the driver side of the oil pan. I have attached a picture. Should there be a bolt here?
May 26, 2013 at 7:40 AM
no picture showed up
May 26, 2013 at 8:14 AM
CAMANOPENNY
I tried to add the photo again. I hope it shows up. Thanks for your time.
May 26, 2013 at 8:19 AM
wont open but yes, all bolts belong there. have it checked at a shop for all bolts and tighten them
May 26, 2013 at 8:23 AM
