Lower motor mount
131,000 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
STEVIE12
  • 55 POSTS
How long can I drive if I need lower motor mount?
Sep 2, 2018 at 6:58 PM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
You will probably be noticing a vibration while driving.The mount itself is about $60.00 and labor will run about $100.00. Hope this helps and thanks for using 2CarPros.
Danny-
Sep 2, 2018 at 8:34 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
I would not drive too long with a broken motor mount. If you drive to work everyday and only have the weekends to work on your own car, then I would say take it easy until Friday with the acceleration from a complete stop, and get the motor mount replaced this weekend coming up. The rubber on the mount is most likely torn and you are probably going to end up tearing it some more.
Sep 3, 2018 at 2:48 AM
STEVIE12
  • 55 POSTS
Thanks.
Sep 3, 2018 at 4:29 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
You are welcome!
Sep 3, 2018 at 9:17 AM
