Lots of play in steering on rough roads mainly
V8 • 4WD • AUTOMATIC
CHEVYGIRL602
I have had a wheel alignment, the tires turn fine when I turn the wheel. The problem I am having is when I hit a bump or rough roads the steering wheel shakes uncontrollably. what could this be, I have read about the steering box and gear columns. Not sure what it is. Please help. i want to buy the parts online, but i would like to have an idea of what the cause really is. The repair man that did the alignment said it would help for a bit, but to get the box replaced. Language barrier so he didn't know how to say it in English.
Sep 10, 2015 at 6:14 AM
RIVERMIKERAT
  • 6,106 POSTS
Turn the steering wheel left and right while watching the front wheels. Do this with the engine off and don't turn the wheel more than 1/4 turn. They should start turning almost immediately. If not, the box might just need to be adjusted.
If the problem was that bad, the |repair man" shouldn't have done the alignment as all it did was waste your money.
Sep 10, 2015 at 6:41 AM
