2005 Chevy Tahoe possible power steering leak
2005 CHEVROLET TAHOE
47,000 MILES • V8 • 2WD • AUTOMATIC
SKUNKBURGER
I have a small (3-5 drops) fluid leak under the right front of the motor. The fluid is NOT engine oil or trans fluid. It is clear with maybe a very slight tinge of red/brown and has no odor. This has been going on for several weeks, I checked all fluid levels to see which is diminishing, but none are getting lower.
This leak does not appear for several minutes to several hours after the vehicle has been parked. The engine is very clean and there is no sign of the leak when viewed from the top. Underneath there is a visible moist area at the right front corner of the oil pan (this is NOT engine oil, it's clear)..
To add to the mystery, it happens intermittently. Sometimes not for days, sometimes several days in a row. Usually a very small amount until today.
My wife drove 5 miles last night, and there was about a teaspoon's worth on the cement this morning. Then we drove 17 miles this morning and two hours later, there is no sign of a leak.
My closest guess is power sterring fluid (due to lack of odor and color). The fluid level is fine, there is no noise, grinding or whining when steering or any degredation of steering performance.
Dec 27, 2009 at 6:10 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Might be A/C compressor oil. PAG oil colorless and odorless. Compressor on right front bolted on very near oil pan. Check it out let me know
Thanks for donate
Dec 27, 2009 at 6:35 AM
SKUNKBURGER
[quote:28e646e3d5="Docfixit"]Hi
Thanks for donate[/quote:28e646e3d5]
I will check... Thx for the fast response!
Dec 27, 2009 at 7:16 AM
SKUNKBURGER
[quote:e7214eaca1="skunkburger"][quote:e7214eaca1="Docfixit"]Hi
Thanks for donate[/quote:e7214eaca1]
I will check... Thx for the fast response![/quote:e7214eaca1]
I am having trouble finding the source of the leak. If it IS the a/c compressor, and it is out of oil, the pulley on the serpentine will still rotate freely right?
I shouldn't have any issues until I try and engage the a/c compressor (turning on the a/c) if I understand it correctly.
I guess what I am saying is a bad or failing compressor won't affect the pulley during operation if the s/c is kept off?
I am due to drive about 500 miles in a few days.....
Dec 28, 2009 at 2:48 PM
DOCFIXIT
  • 18,828 POSTS
Pully not effected try A/C now see if it operates normally. If not do not use defrost because that engages A/C comp.
Dec 29, 2009 at 12:54 AM
