Here is a guide that we need to start looking at in order to start narrowing this down. However, do you have a check engine light? If so, we need to get the codes before we go much further. If you don't have the ability to pull codes, you can go to most any parts store and they will get them for you free of charge.
https://www.2carpros.com/articles/symptoms-of-low-engine-power
Lastly, let me know if you have the ability to monitor live data with a scan tool. Clearly if you can't pull codes, then you can't monitor data but I need to ask because that is most likely going to be necessary.
Thanks
Saturday, September 28th, 2019 AT 12:02 PM
