Van running Sluggish, bucks at 35,000PRM
185,000 MILES
DSIMMONS78
Van was working fine, had a dead battery and someone jumped the battery for us. After that experiencing weird behaviors which started off as buck/jerking at 35,000 RPM, then you let your foot off the peddle and back on then when the RPM's drop a little you re-apply the gas and it goes, but now we are experiencing extremely poor gas mileage, and the van is sluggish to take off from a dead stop or actually to just accelerate.
May 2, 2013 at 11:50 PM
HMAC300
  • 48,601 POSTS
bad battery cause all kinds of driveability problems . that needs to be done first then driven then scanned for codes and check fuel pressure
May 3, 2013 at 12:08 AM
DSIMMONS78
I have already replaced the battery and the issue remained, there are 2 codes showing. One for a EGR sensor and one for the crank shaft senor.
May 3, 2013 at 12:38 AM
HMAC300
  • 48,601 POSTS
the crank sensor could be that or apoor connection. if you can wiggle it and the car stops youneed the connector. egr can be the valveor it's plugged.
May 3, 2013 at 2:52 AM
