I sprayed some WD-40 into the ignition key hole at some point, and that appeared to have caused the problem, for this also makes dirt get accumulated/stuck in the switch.
So I rinsed it out with alcohol, and then let it dry, then got some key lubricant(graphite from Lowe's), and that solved the stickiness. Still going strong
Was this helpful?
Friday, May 7th, 2021 AT 11:39 AM
(Merged)
