1999 Dodge Neon Ignition?
1999 DODGE NEON
120,000 MILES • 4 CYL • 2WD • AUTOMATIC
MJH204
While driving, my son stated vehicle ran fine but gauges began moving from one extreme to the other. Once shut off, it won't start most of the time. When I got in, I heard a ticking from dash area. I then put key in ignition and the gas and battery guage began moving as if car was on. They shut down when I removed key from ignition. Ignition was not turned to start or aux. when the gauges moved. Is this a problem with the ignition switch itself?
Feb 5, 2008 at 4:09 PM
BMRFIXIT
  • 19,053 POSTS
Check and charge the battery
start car and check alternator and charging system
Feb 10, 2008 at 11:40 AM
