Engine cranks but does not start and lost four out of six quarts of oil
126,000 MILES • 4.0L • V8
CHRISTOPHER RANDOLPH
Cranks but wont start. Is there something that needs reset, possibly?
Jul 28, 2021 at 8:41 PM
SQM
  • 6,383 POSTS
First of I am assuming you have added proper amount of oil.
Did the vehicle loose all of that oil all of a sudden, or has it been running low for sometime?
If the vehicle shut down due to lack of oil/oil pressure, you could have damaged engine internals.
Is the check engine light illuminated? Sometimes in no start, there is a fault code. Which can point us to the right direction.
https://www.2carpros.com/articles/bmw-obd1-1995-and-earlier-code-definitions-and-retrieval-procedure
https://youtu.be/vMwTzURWXmk
If the engine cranks but does not start it could be either for no spark or no fuel.
I would suggest first check for codes then go from there.
Please let me know what you find.
Jul 29, 2021 at 12:01 AM
